Platform: J-body
all instrument lights come on, guages stop working
Old May 3, 2008 | 7:41 PM
Ratman667's Avatar
Default all instrument lights come on, guages stop working
ok, so i just bought a 2000 Cavalier coup with the 2200 series motor and manual trans. i only paid $1000, so i was expecting some problems. here is what its doing. i can start the car and let it idle and nothing will happen but as soon as i put it in gear all of the lights on the instrument panel will light up and the guages will work for a bit, then go down like when the car is off. if i am crusing in one gear only the check engine light and theft alarm light will come on. but the guages still turn on and off. i also get a message on the odometer that just says "error". at first i was thinking it could be the vehicle speed sensor, but i cannot find any listing for one for a manual trans at any parts house. another thought was the PMC could be bad. i wont be able to run a diagnostic on it untill thursday. on a side note, it does have an aftermarket stereo. if anyone has had this problem, please let me know what it was.
Old May 3, 2008 | 7:51 PM
Ratman667's Avatar
Default RE: all instrument lights come on, guages stop working
ok, search came up empty, but i found my answer. its a bad ground behind the instrument panel.
https://chevroletforum.com/m_55275/tm.htm that is the post i found
Old May 4, 2008 | 5:35 PM
Ratman667's Avatar
i talked to one of the guys at work today who used to have a cavalier and he said he had the same problem. he recomended running a wire from the ground prong (fender side closest to the firewall) to the negative battery terminal. i tried it since it is easier than removing the dash and it works. now as soon as i finnish the brakes, tune up and fluid changes, i will have a nice reliable car. maybe this will help someone.
hzlq57
Jun 7, 2016 2:06 AM
midnight1s1s
Sonic (Aveo)
Jul 28, 2014 10:03 PM
Kay-G
Oct 19, 2010 12:56 PM
Chvymn420
Sep 9, 2007 12:59 PM
Chvymn420
Sep 3, 2007 11:12 AM
