Platform: J-body
Brake interferes w/ Turn sig/Hazard flasher fuse.
Old Aug 8, 2009 | 11:25 PM
brandon0409's Avatar
Default Brake interferes w/ Turn sig/Hazard flasher fuse.
I have a 1998 Chevy Cavalier 2.2L Automatic Trans
History:
My turn signals stopped working recently. I finally figured out that it was the 5-prong flasher fuse (conglomerated Hazard/turn signal) located under neath the dashboard. I bought a replacement from Advance Auto. Blinkers now work fine.
Onto my NEW problem::
Once installed, a problem arose.
When the break pedal is pushed (a button or switch is depressed under the dash above the pedal I assume to relay to the tail lights and) the Turn signal flasher fuse makes 2 clicks (as if the turn signal is on) but the lights don't flash. This happens each time the brake pedal is pressed.
I confirmed the switch under the dash by pressing the button with my finger.
Question:
Could I have bought a faulty Flasher fuse?
Is the generic "Advance Auto" brand a crappy brand?
What can I do to fix this?
Thanks
Old Aug 10, 2009 | 11:53 AM
Please someone respond.
Old Aug 11, 2009 | 3:49 PM
Okay, I figured out the problem.
The Advance Auto brand Flasher fuse is not compatible with the car.
I went to my local Chevy Dealer and bought the authentic GM replacement part. Once it was installed, everything worked fine.
Hectorson3
Sep 13, 2014 12:22 PM
666threesixes666
Aug 18, 2012 7:18 PM
L1NK1NP4RK
Jul 8, 2012 11:27 AM
Skysarge
Apr 21, 2012 10:36 AM
Manor_Mullet
Apr 28, 2008 2:13 PM
