Platform: J-body
cavalier 2 door hinge pin replacement
Old Apr 27, 2011 | 7:39 PM
peshewa's Avatar
Default cavalier 2 door hinge pin replacement
My good friend has a 1998 z24 2 door & the hinge pins on his drivers door are totally bad. I have replaced hinge pins before, but none so strange as these. It almost looks like I need to use an air chisel to chop off the tops of them then try to drag out the stubs on the bottom. The new pins & bushings look to be held in by the e-clips provided & the shape is flattened out on the other end of the pin. I cant get a drill bit on top of it due to the shape of the door. Does anyone know the tricks to do this job? I am doing this on his car asap & I don't want to screw anything up.
Rupesy
Jun 6, 2011 1:51 PM
paulrbrown
Apr 13, 2010 7:23 AM
Chevelle_malibu6980
Dec 21, 2009 8:39 AM
2007BURB
Jun 13, 2009 12:52 AM
rstank
Jun 21, 2008 4:57 PM
