Platform: J-body
cavalier shakes when I break
Old Apr 12, 2007 | 11:39 PM
coling659's Avatar
Default cavalier shakes when I break
Ok...I think this is a break issue but not sure. 2002 cavalier shakes when I break. It's not a viloent shake but it feels like I am going over a bumby road when I break. My brakes don't squeak and I seem to have plenty of braking power...Any help is grateful...thanks..
Old Apr 13, 2007 | 12:39 AM
ruffrider285's Avatar
Default RE: cavalier shakes when I break
I had that same exact problem, its either your lower ball joints...which are only $30 a piece, or your brake calipers which are $35 a piece....i had to replace both...and easy and inexpensive job.
Old Apr 24, 2007 | 1:09 PM
jbuist's Avatar
I dont think its your ball joints or calipers. The problem is defintely a brake problem. The best answer is probably that your rotors are warped. When you apply the break your rotors heat up, and if they heat up enough the steel becomes weaker, allowing the rotor to go out of shape. So when you apply the brake, the pad is rubbing up and down along the rotor, causing it to shake.
Old Apr 24, 2007 | 11:28 PM
jrocha3's Avatar
I agree its the rotors, you can get them resurfaced at just about any auto store, but if you have the money just buy new ones, the problem should only be with the front rotors.
Old Apr 26, 2007 | 10:05 PM
cavyone's Avatar
My car used to shake alot. I put brand new Rotors and brake pads and all that shaking went away. I did the replacements this past weekend. im about 98% sure its your rotors.
Old Apr 29, 2007 | 9:55 PM
Cavigurl85's Avatar
ORIGINAL: jbuist
i had that problem a few days ago... my boyfriend ended up ttaken my rotors off brought them to his work and worked on them.. and now my car runs fine and my car doesnt shake anymore
Cavlier2003
May 4, 2014 11:32 AM
sethlives1
Cobalt
Oct 7, 2007 7:39 PM
cheyenne06
Jul 13, 2007 11:14 AM
cavyone
May 25, 2007 2:16 PM
birmingham
Mar 4, 2007 5:29 PM
