Platform: J-body
Changing Manual Trans Fluid on 2003
Old Jul 30, 2007 | 2:48 PM
mikey45's Avatar
Default Changing Manual Trans Fluid on 2003
Hi, i can't seem to find the drain plug on the manual transaxle, could anyone point me in the right direction?
Old Jul 31, 2007 | 2:18 PM
ruffrider285's Avatar
Default RE: Changing Manual Trans Fluid on 2003
You usually drain trans fluid by just removing the pan. There isnt a drain plug.
Old Jul 31, 2007 | 3:31 PM
HaryB's Avatar
I thought the only transmission with a pan was an automatic tranny. There should be a plug to check the fluid and a plug to drain the manual transmission. New manual trannys have a range of oil from 90 weight gear oil to ATF. Some use motor oil. Check your manual to see which oil your tranny has. It will also tell you when it should be changed.
Harry
Old Aug 1, 2007 | 10:15 AM
mikey45's Avatar
i have a haynes manual, but it is quite vague and has no indication of where the plug is. i may have an idea where it is but its position is about 4-5 inches above the bottom of the transaxle and wouldn't drain completely unless it was pumped out or something.
wep54
Nov 11, 2013 8:49 AM
aboyaser
Nov 20, 2012 9:04 AM
2wd-K5
Cobalt
Feb 5, 2011 8:57 PM
bwaple
Mar 6, 2008 8:30 AM
tmoney2514
Mar 26, 2007 11:05 AM
