Platform: J-body
Coolant leak from exhaust
Old May 27, 2010 | 9:05 PM
teefaw's Avatar
Default Coolant leak from exhaust
Just (4 days ago) replaced the head gasket and studs/bolts on my son's 97 2.2OHV. Horrible job, by the way - but the car was fine until today when it wouldn't start (again). Before the gasket replacement he had coolant spraying out from 2 studs - guess they'd stretched - and the gasket was, indeed, blown. Cylinders were full of coolant too. Thorough inspection of head and block revealed no other damage though. I was going to replace the thermostat today but when he tried to start the car to go to Autozone for a new one we discovered coolant leaking - under pressure as the engine turned - from the exhaust pipe to exhaust manifold joint! He'd only driven the car 4 times for around 15 miles total and lost 2 or 3 pints from the header tank over the previous 4 days.
Anyone have any ideas what the problem might be?
T4
Old May 27, 2010 | 9:18 PM
old dog's Avatar
Default leak
i would have had the head checked for straightness and pressure tested before i put it back on .
Old May 27, 2010 | 9:22 PM
MDTAHOE's Avatar
Professional Mechanic
x2 ^^^^
Old May 27, 2010 | 9:32 PM
teefaw's Avatar
But surely (I know, don't call you Shirley) that wouldn't result in a coolant leak at the exhaust pipe to manifold joint, would it? No sign anywhere else of coolant leak.
T4
Old May 27, 2010 | 9:36 PM
MDTAHOE's Avatar
It would have to be leaking into the exhaust inside the engine.
Old May 27, 2010 | 10:10 PM
teefaw's Avatar
So, a warp or a crack then. Seems a bit terminal!
dlaroche
Oct 29, 2014 7:17 PM
95wt
May 30, 2008 3:07 PM
formulalt1power
Mar 14, 2007 6:34 PM
ffdaryl
Mar 1, 2007 2:52 AM
bc56845
Nov 29, 2006 2:12 AM
