Platform: J-body
Dim headlights
Old Jun 4, 2012 | 5:38 PM
whit6419's Avatar
Default Dim headlights
Hello Everyone,
I'm looking for help with a headlight issue. I have a 2003 Cavalier and both headlights are very dim on high or low beam. Neither one seems brighter than the other. I have put in "brighter" bulbs with no difference. Any help would be greatly appreciated. Thank you.
Old Jun 4, 2012 | 9:24 PM
MDTAHOE's Avatar
Professional Mechanic
Check the ground circuit.
Old Jun 5, 2012 | 7:47 AM
kevinkpk's Avatar
Whats the lenses look like?
Old Jun 8, 2012 | 5:04 AM
whit6419's Avatar
Thanks guys. The lens are ok. I polished them recently because they were quite cloudy. As far as checking the ground circuit, are there certain color wires I should check? I'm reasonably mechanical but not that adept with electrical. Thanks again for the help.
Old Jun 8, 2012 | 4:27 PM
johntaps's Avatar
Former Sponsor
Look at ALL the wires near the battery. I believe there is a ground under the battery.
Old Jun 8, 2012 | 6:04 PM
Segfault's Avatar
Take a voltmeter and measure the voltage between the ground of headlight bulb and battery negative terminal - while the headlight is on of course. If it measures more than 0.1 V you have a ground problem.
bayerasa
Mar 5, 2014 11:41 AM
mxz583
Sep 15, 2009 9:17 PM
04extv8
Feb 14, 2007 1:16 AM
cowboys
Dec 18, 2006 12:28 AM
wally123
Dec 4, 2006 10:50 PM
