Platform: J-body
Get gas out of tank? 05 Cav
Old Jun 16, 2016 | 4:40 PM
imatt88's Avatar
Default Get gas out of tank? 05 Cav
Hey all,
How do i get about a 1/2 a tank of fuel out of an 05 Cav without making it a major operation?
I parked the car about 1.5 yars ago after all the gauges stopped working
Now i want to get it running again, but i'm afraid to start it.....
Any suggestions?
Cheers, ian
Old Jun 16, 2016 | 5:33 PM
I used a small hand pump that I bought from Harbor Freight for about $5.00. No electricity and no chance of a spark.
Old Jun 16, 2016 | 7:58 PM
imatt88's Avatar
oldchevy,
Thanks for the reply,
If I can get the gas out, will putting fresh gas in solve the problem of starting it, or do I need to do anything else?
Cheers, Ian
Old Jun 17, 2016 | 10:31 AM
The fuel lines will also have the old fuel in them. If the gas is really bad then they should be flushed out.
Old Jun 18, 2016 | 8:52 AM
imatt88's Avatar
oldchevy,
Well it is Florida, I would assume the gas is like gum. LOL
Any suggestions? Are there any additives I could use to clean the lines, or will I have to blow them out with air? Not sure what to do
Cheers, Ian
Old Jun 18, 2016 | 11:12 AM
You could disconnect the fuel line at the engine and run the fuel pump and let it pump the old gas out. Change the fuel filter after doing this.
Old Jun 18, 2016 | 6:14 PM
imatt88's Avatar
Thats not a bad idea. I ll have to find the fuel line. Not sure where it is
Cheers, ian
