Platform: J-body
Headlight problem
Old Mar 17, 2009 | 11:21 AM
steelerfan7p's Avatar
Default Headlight problem
I have a '97 2.2L auto. If it is cold out the headlights do not want to turn on right away. The running lights and high beams work fine, but the low beams do not turn on for a while. After idling for 10-15 min or running the car on the highway they finally come on. I have heard about a wire corrosion problem but cannot find any threads on this. Can someone please help me or direct me somewhere this is explained? Thanks in advance.
Old Mar 23, 2009 | 4:10 PM
EvansBlue's Avatar
If its below freezing, you likely have condensation in the headlight relay and its freezing the relay.
Old Mar 29, 2009 | 5:15 PM
cive666's Avatar
It never hurts to check your grounds and even the positive connections, any connection has a possibility for corrosion which can cause a voltage drop.
Easiest way to check the relay would be to take it out when this problem would occur and just jumper it. I think they are in front of the radiator attached the front bumper, don't quote me on that though.
garyv990
Feb 11, 2015 9:52 PM
flynnstone_45
Astro
Feb 10, 2007 10:46 AM
mikestopford
Sep 2, 2006 6:34 PM
Schlickster
Jul 25, 2006 2:36 PM
jorgie5150
May 10, 2006 6:56 AM
