Platform: J-body
HVAC panel not lighting up fix, 95-02.
Old Jul 24, 2007 | 9:59 AM
The01Cav's Avatar
Default HVAC panel not lighting up fix, 95-02.
Well I was having a issue with my hvac panel not lighting up. Also I noticed that it used led type bulbs instead of halogens. I tried to pull them out but I couldn't get them. Well I have a 89 beretta gt parts car at my house and looked at that. Well I discovered that the harness colors for the lighting are the same. I cut the yellow and grey wire out and walked back to my cavalier and the bulb sockets fit into the cavaliers hvac panel like a glove. I proceeded to cut the yellow and grey wire and just twisted them together. I hit the light switch and instantly they light up. I must say they're a slight bit brighter as well. So I pulled the wires back apart used a couple butt connectors and connected the wires together and wrapped electrical tape around them. I put everything back together and now it works perfect and your able to change the bulbs with ease. Just though that I would let everyone know that has had this issue.
Old Aug 31, 2007 | 6:41 PM
nolanz24's Avatar
Default RE: HVAC panel not lighting up fix, 95-02.
thanks for posting this im having the same problem right now.
moejean
Nov 6, 2013 9:24 PM
jwilks
Apr 8, 2013 6:40 AM
thejumpsuitman
Sep 13, 2010 4:25 PM
cgcomeaux
Jan 14, 2008 12:21 PM
00blazer
Jul 12, 2006 10:04 PM
