Platform: J-body
no fuel
Old Jan 14, 2008 | 11:32 PM
smitty's Avatar
Default no fuel
at first we thought the problem was the fuel pump itself but after i dropped the tank and checked the pump we figured out that the pump worked and we took a test light into the hook up thingy and found out it wasent getting power to the pump we checked the fuses and all but we still have no idea
Old Jan 15, 2008 | 7:37 AM
dewey's Avatar
Default RE: no fuel
What year, engine size? With the engine cranking, do you have spark at the plugs? Are there any codes?
Old Jan 15, 2008 | 2:54 PM
smitty's Avatar
Default RE: no fuel
its a 98 z24 with the 2.4 i havent been able to check the codes because i cant get it to a shop the check engine light was on already because of my exhaust
Old Jan 16, 2008 | 1:14 PM
dewey's Avatar
Default RE: no fuel
You could do some testing at the fuel pump relay. If the relay is in a power distrubution center, just unplug it. Use a testlite and with the engine cranking, check for voltage at the terminals where the relay plugs in. Two terminals should be hot, if only one, then the computer may not be signaling the relay to energize. Can you tell if there is an rpm signal?
I just wanted to add, you might check for a signal from the crank and cam sensors. I can't tell you to replace anything withoutdoing some testing.
hunter10220
May 18, 2011 8:37 PM
scottkern3
Dec 7, 2009 7:53 PM
harascho
May 11, 2009 2:10 AM
MrPuzzlez
Jan 4, 2009 12:02 AM
