Platform: J-body
Steering 94
Old Aug 15, 2008 | 4:15 AM
waltd140's Avatar
Default Steering 94
Car has an issue going left, but not right. Seems to bind going left, like the power steering pump is not working. This happens to be worse the slower you go. It's fine going right. Any suggestions on what it could be?
Old Aug 16, 2008 | 11:03 AM
GraveDigger's Avatar
Default RE: Steering 94
Is it losing fluid? Sounds like a bad rack and pinion to me. How many miles on the car?
Old Aug 18, 2008 | 4:22 AM
waltd140's Avatar
Not losing fluid. About 125k
Old Aug 18, 2008 | 6:22 AM
If you have any power assist at all, the pump is probably fine. All it's gonna do is providepressure, no matter what side you're turning to. If it was me, I'd try draining the fluid and run some Seafoam through it to clean the system out. Re-fill with fresh fluid and see if it works. Is the fluid in the pump resevoir dirty or have anything in it, like metal shavings? Seafoam is cheap, and worth a try (in my opinion) since you may be looking at a rack replacement.
Old Sep 12, 2008 | 6:36 PM
waltd140's Avatar
Power steering fluid looks bad. Seems I am doing a rack on this. Any advise?
Old Sep 14, 2008 | 10:18 PM
shawnvw's Avatar
Banned
I'm gonna say let someone else do it.....it is a pita
Old Sep 28, 2008 | 5:56 AM
waltd140's Avatar
Really? Doesn't look too bad. A few bolts & the pump hoses. Is it really a pain?
Old Nov 29, 2008 | 6:17 AM
waltd140's Avatar
Quick update: It was the rack. Got a new one for $80 & had someone put it in. He had it completed in about 4 hours, but would not say how easy it was.
Thanks for the help
bobbygrady
Aug 14, 2013 8:57 AM
w002mia
Jun 29, 2013 3:27 AM
w002mia
Mar 18, 2013 11:42 AM
cyberrkatz
Jan 31, 2011 8:54 AM
