el camino
Old Jul 10, 2012 | 5:34 PM
mcapela's Avatar
Default el camino
I have a 1987 El Camino with a 4.3 V-6. When I shut off the key the vehicle continues to run without missing a beat. It's not dieseling it just continues to run as if I never turned it off. PLEASE HELP ! ! ! I have tried everything.
Old Jul 10, 2012 | 7:37 PM
kevinkpk's Avatar
Could be the switch, however there is a small rod that runs from the key to the switch in the steering column, if it starts, it cannot be an issue with that other than not moving far enough back when you turn the key to off. My guess is ignition switch, not the key cylinder.
Old Jul 10, 2012 | 8:00 PM
mcapela's Avatar
i tried unplugging the ignition switch down on the column and it still acts the same. does that mean the switch is good. Also when i put a test light down on the fuse block on the ignition slots it goes on and off with the key. any help will be greatly appreciated....
Old Jul 10, 2012 | 8:02 PM
mcapela's Avatar
also the ignition connections on the fuse block stay hot with the key off until i kill the engine and then they are not hot.
Old Jul 10, 2012 | 8:05 PM
kevinkpk's Avatar
Has there been any aftermarket stuff done it before this problem occured?
Old Jul 10, 2012 | 8:08 PM
kevinkpk's Avatar
Is there an ignition relay in there? If so, the contacts could be welded together, and no matter if you shut the power off to the coil it will stay running.
Old Jul 10, 2012 | 8:47 PM
mcapela's Avatar
no aftermarket stuff it is completely stock. someone told me they think its backfeeding power.
Old Jul 10, 2012 | 9:08 PM
kevinkpk's Avatar
Read post #6
Old Jul 11, 2012 | 1:14 PM
mcapela's Avatar
There is no ignition relay on this vehicle. Any other suggestions ? Thanks
Old Jul 11, 2012 | 2:34 PM
kevinkpk's Avatar
What I would suggest, locate the wire to the distributor, trace it back. Could be it is tied into +12 volt wire due to insulation rub, heat.
