Running Rough Question
Old Sep 14, 2021 | 10:31 PM
RadDad68Chevelle's Avatar
Default Running Rough Question
It’s a 68 Chevelle with a SB350. QuadraJet carb. It struggles ‘under load’. Starts right up idles smoothly.
1) cylinder 8 header reaches max temp of about 220 degrees all else 500 plus
2) cylinder 8 has compression of 140 vs 150 on all others
I’ve changed plugs, cap, rotor, wires.
I’ve pulled the valve cover and rockers / arms look fine.
im down to the carb.
Any other ideas? Please help so frustrated!
Old Sep 17, 2021 | 9:46 AM
kevinkpk's Avatar
"struggles under load". As in not getting enough gas? If you hammer the throttle wide open, does it stall?
chaos65
K5 Blazer
Aug 26, 2015 5:01 PM
mnchevy56
Mar 17, 2013 9:13 PM
oldyellowchevy
Oct 15, 2012 9:33 PM
ply48
Dec 23, 2007 12:24 PM
joesjeep
Aug 29, 2006 7:20 PM
