Timing problem
Old Oct 25, 2022 | 12:25 PM
WesleyW's Avatar
Default Timing problem
Hi, Wes here. I've built a sbc 383 stroker. This is what I've checked. Turned engine until #1 intake valve closed. Bumped engine a little bit to get harmonic balancer to tdc. Checked distributor rotar, pointing straight to #1. Carburetor primed, cranked and cranked it, would not fire. Had to turn the distributor so much that the vacuum advance can is almost touching the intake. This barely moved the timing line on the balancer. Line is still too far retarded. Can't figure this out. Any suggestions? Thanks
Old Oct 25, 2022 | 4:21 PM
kevinkpk's Avatar
If this is a point distributor, I'd suggest the point's are slipping. Tighten the hold down screws.
Reconyx_01
1988 - 1998 (GMT400)
Dec 16, 2019 11:19 AM
timmy7728
Oct 20, 2012 7:31 PM
C10moneyvortex
Jul 24, 2012 9:18 AM
cduarte1982
K5 Blazer
May 22, 2010 6:26 PM
attmchappo
Jul 26, 2006 2:27 AM
