1986 K10 Scottsdale 305 carburetors
Old Dec 2, 2023 | 9:39 AM
DSetzer's Avatar
Default 1986 K10 Scottsdale 305 carburetors
It runs OK carb has been rebuilt. Idles high or low whatever it feels like at the time. I'm not a carburetor guy, but I think I can put a new choke on it. Any suggestions? Thanks
Old Dec 2, 2023 | 9:45 AM
Rednucleus's Avatar
Welcome to Chevy! More details please - are you saying it surges faster/slower, or sometimes runs hi, other times low? Is it tied to operating temp?? How's drivability??
Old Dec 2, 2023 | 10:12 AM
Welcome from Florida. What condition is the mechanical fuel pump in? Is the fuel filter clean?
Old Dec 3, 2023 | 7:22 AM
DSetzer's Avatar
Have to pump pedal 3-4 times to crank. Idle can be high, low or good after cranking, no surges. If idle stays high then it runs on after I cut it off. And choke indicator light blinks sometimes when I cut it off. Operating temp is good. Drives good after warm up.
Old Dec 3, 2023 | 7:24 AM
DSetzer's Avatar
I haven't checked the fuel pump or filter. Valve cover gaskets leak, so I'll check those when I replace gaskets. Thanks
Old Dec 3, 2023 | 9:02 AM
dpieroni3's Avatar
You could start by checking that the choke is working as designed. Example: is the choke coil working and has power to it, does the choke pull off work and is adjusted correctly, is the linkage free. Just a thought .
jmarsden26
Feb 14, 2013 4:07 PM
cherrycj7
Apr 5, 2010 10:43 PM
Cutty
Jul 20, 2007 5:40 PM
83capriceguy
Dec 7, 2006 1:28 PM
