78 C30 manual transmission HELP
Old Jul 17, 2021 | 6:25 PM
Jelag's Avatar
Default 78 C30 manual transmission HELP
So I've got my kids old farm truck in the shop pulling it down for a clutch....
Normally on a top loading transmission I'd unbolt the top plate to remove the shifter and pieces to allow transmission to move back and out. On this transmission that's not an option. I do have a round *** cast into the case what looks like a pin that runs through the shifter. But the pin doesn't move with a drift.
So I thought that maybe a lock pin that pushes in from both sides and releases the shifter but doesn't seem to be want to .move.
Looked to see if the shift arm unscrew, and it doesn't seem to do that.
So I admit that after 50 years of turning wrenches I can't see how to pull the lever out... so then lower the transmission and slide it back..
Someone have a thought. Of course I'm hot and tired, and looking for some insite.
Old Jul 17, 2021 | 7:07 PM
kevinkpk's Avatar
Not exactly sure what you hve or asking. If it is a granny transmission, (truck) in order to lift the shifter plate, and reinstall it, put the shifter half way in reverse.
Old Jul 18, 2021 | 11:46 AM
burnhedge's Avatar
Not sure exactly what you’re asking, but if you just need to remove the shifter; it has a lock ring at the base. Hit it with a little lubricant, push down and turn.
cannibal carl
HHR
May 20, 2021 10:08 AM
tank1949
1988 - 1998 (GMT400)
Dec 21, 2020 12:25 PM
FDR
Dec 10, 2018 11:49 PM
John Hart
Jun 2, 2008 5:48 AM
sparker7062
Chevelle & El Camino
Nov 7, 2006 2:02 AM
