Help identifying engine and tranny
Old Apr 27, 2019 | 1:04 PM
  #11
texrex's Avatar
looks like a 400 trans , 350 v8 with the dip stick on the drivers side .
looks like a mid 70s drive train .
shift seal leak on trans
Old Apr 28, 2019 | 3:14 PM
  #12
Frankwhoa's Avatar
Thanks! How do I fix that leak, just tighten it a little, torque it, or is there a gasket/o-ring?
Old Apr 28, 2019 | 4:10 PM
  #13
texrex's Avatar
The part number below is the installer and remover . You order a shift shaft seal ,buy 2-3 . The edge of the shaft is sharp and can tear the seal. You can tape the end of the shaft before install. Your rear seal is leaking a bit , you might do a seal too if the bushing is not wore out . If truck sits up for a while transmission will leak. Nappa Auto PartsBK 7769250PRODUCT LINE :Balkamp
Old Dec 4, 2024 | 2:29 PM
  #14
fatblazer1973's Avatar
You can also look at the VIN number if the truck hasn't been altered. I was just reading this page on usa1 industries 1981-1987 chevy truck vin decoder
