Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2009 2.2L massive oil leak!
Old Oct 22, 2022 | 8:17 PM
  #11
tedz's Avatar
Here’s a video showing the amount of leak.
File Type: mov
Old Oct 22, 2022 | 8:21 PM
  #12
tedz's Avatar
Another video showing the area of the leak.
File Type: mov
Old Oct 25, 2022 | 12:54 AM
  #13
Kornbizkitz's Avatar
that is the same exact leak I have. Weird there is so many like this. Wonder if could be JB Weld? Or need to replace whole cylinder head?
Old Nov 7, 2022 | 12:43 PM
  #14
Cipherion's Avatar
Default Hidden oil leak 2009 Cobalt
Originally Posted by ajparry89
Hey all,
Massive might be an over statement, but its a steady drip while the engine is running! coming from the exhaust side, back corner of the motor. its not the valve cover, as I just replaced that and it is dry. My guess is its the head gasket, but no matter which way I twist my neck and eyes, using a mirror or not, I can not get a good view of where it is actually coming from. But its a steady drip that comes down between the back of the motor and the transmission. Are these known for head gaskets leaking oil? is there something else on that back corner that oil could possibly be leaking from? I cant see any other possibilities, yet I cant get an actual visual, so I dont want to assume. Anybody else have experience with oil leaks there? thanks!
The oil pressure sensor is a common leak. It’s above the starter just below and left of the oil filter. Hope this helps.
suzuki-guy
Jan 15, 2022 3:35 PM
Typerod
Jan 5, 2019 4:14 PM
April Villegas
Sonic (Aveo)
Dec 22, 2017 4:20 AM
spwwalsh
Dec 31, 2009 8:14 PM
sixpack_sid
Nov 14, 2008 11:21 AM
