Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Cobalt security
Old May 19, 2021 | 12:30 PM
joelshort's Avatar
Question Cobalt security
I've got a 02 chevy cobalt with the security light solid on it ran fine then someone hooked up jumper cables the wrong way positive to negative and negative to positive it fried the starter so I replaced that now the car will start for a few seconds and stall over and over agian the security light was flashing so I did the key on for 10min off for 5sec three times now the security light will stay on solid and will not go out after 10 min or at all Do you think this could be an ecu issue
Old May 19, 2021 | 1:33 PM
plug a scan tool into the vehicle and see if it communicates with the pcm...if yes, the pcm is probably ok. post the theft deterrent codes.
cobalts were not made in untill 2005 so post back with the codes, model year and engine size
Old May 26, 2021 | 2:01 PM
joelshort's Avatar
Default NO DTCs Found
The car is a 2006 (10/05) I read the codes and there are no active or pending codes found I am going to attatch some pictures
Old May 26, 2021 | 2:06 PM
joelshort's Avatar
sorry for the late reply ive been very busy with work but an help will be greatly appreciated
Old May 26, 2021 | 10:02 PM
the theft light is on...padlock...so theft codes are stored....they must be read with a scan tool that access body codes. a cheap code reader only accesses powertrain codes.
what ru using to scan with?
Old May 26, 2021 | 10:19 PM
joelshort's Avatar
Default cheap android phone scanner
Its a amazon wifi dongle thing called (icar)
Amazon Amazon
and the app im using is called car scanner or obd mary from the google play store on my phone
Old May 27, 2021 | 9:25 AM
it won't access body codes
Old May 27, 2021 | 10:11 AM
joelshort's Avatar
Default scan tool
are tyhere any scan tools 200- 400 bucks that will acsess all the modules and any that suport bi directional functions that you reccomend
Old May 27, 2021 | 1:42 PM
autoenginuity | Unleash the Diagnostics Power Built into Your Vehi…
Old May 30, 2021 | 11:31 PM
joelshort's Avatar
thank you and insight onto how to security system in this car works is greatly appreciated thanksthank you and insight onto how to security system in this car works is greatly appreciated thanks
