Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Headlights Dim at idle
Old Jan 31, 2021 | 9:13 PM
angellscobalt07's Avatar
Default Headlights Dim at idle
Hi there, newbie here. I have a 07 Chevy Cobalt LS that I've been trying to fix up myself. One of the issues I've been having is the headlights will dim and fluctuate in intensity when they're on, noticeable at night. They would dim at the same pace of the dashboard which seemed to be in time with listening to the engine.
I replaced the battery, serpentine belt and alternator, in that order. Maybe about a week apart from each other. Anyway, I was dreading and putting off replacing the alternator because of how difficult it was to get to but after the last two attempts with replacing the 10 year old battery and super worn out belt, the alternator seemed it was going to be problem solver (after reading it was most likely the culprit on numerous forums/websites).
After tearing up my arms reaching in and cursing all morning, I was able to get the alternator replaced. Drives fine, arguably feels like it drives with a little more pep but maybe that's in my head.
Come nighttime, I could fully test to see if my issue was gone. At first glance, the lights were consistently brighter and the dash no longer dims at all. As I sat there and looked closely, I turned the heater on full blast and noticed the headlight intensity changed subtly. I drove the car around the block a few times to see if I'd notice it on the road and if maybe the new alternator needed a quick drive before doing its thing properly. I don't notice it much while driving since it was so embarrisingly obvious before. I pulled back into the driveway and stared at the wall being hit with headlights some more and that's when I noticed it was still dimming ever so slightly. The intervals at which it dimmed is much longer now, say 3-5 seconds. And the dim is very subtle, but I know it's there and my fear is that it'll get worse over time again like when I noticed it for the first time about a year or so ago.
Can anyone point me in the direction of my next step should be? Will it go away in a couple days with the new alternator? I made sure connections to the alternator and battery were solid and snug.
angellscobalt07
Feb 1, 2021 1:40 PM
PsychoDodo
May 24, 2020 9:47 AM
ZeroSeven
Apr 16, 2019 5:11 PM
jlm6740
Mar 5, 2008 11:26 PM
