Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Need help with sway bar bushing bolt
Old Jun 26, 2012 | 9:42 PM
AndreasChen's Avatar
Default Need help with sway bar bushing bolt
Hi all,
New to this site
I got a pair of new bolts from dealer today. However I am very confused about the black plastic ring over the bolt.
Should I screw the bolt in with that piece of plastic on? I found it impossible to push the ring through the bracket hole...
Thanks for any input
Old Jun 27, 2012 | 12:08 PM
I would say that since the old one didn't have it, you don't need it. I did notice that the new bolt is longer than the old one. Will this still fit and tighten up? Also, why did you need new bolts?
Old Jun 27, 2012 | 1:16 PM
Old bolts comes without the plastic ring, but the bracket moves b/c the old bolts are way to small to hold the bracket... I am wondering if the plastic thing is a part of the bolt to keep the bracket from moving back and forth...
I want a new set of bolts b/c the sway bar noise has been there forever, even with new bushings... I worked on the bolts too many times and its kind of rounded off...
burrellp
Oct 23, 2014 6:02 PM
tmmii
Aug 6, 2014 9:31 AM
RockVegas
Aug 31, 2013 5:08 PM
Classical Glass
Sep 2, 2007 11:09 PM
Classical Glass
Aug 8, 2007 7:31 PM
