Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
power window not working
Old Apr 1, 2012 | 6:00 PM
samuelleah's Avatar
Default power window not working
2010 cobalt.....rear driver window does not work from either door switch...occasionally the rear passenger window acts up in the same way...where to start?....thanks
Old May 2, 2012 | 9:06 PM
Paul79UF's Avatar
A 2010 should still be under warranty. If you can re-create the problem for the dealership, that's where I would start.
Otherwise, you might need to replace the switch or the window motor.
justin69
Feb 28, 2015 2:54 PM
dlittle
Cobalt
Aug 8, 2012 1:50 PM
davbell22602
Mar 10, 2010 8:36 PM
drewsm3
Jul 26, 2006 9:22 PM
