starting problem 2007 chevy colbalt
dash lights come on but the car want turn over sometimes starts when i jump it or wait awhile battery not dead im thinking bad ground wire but where
Start with the basics first.
check the fuses,
under fuse block
IP IGN fuse (20amp)
Crank fuse (30amp)
then check the crank relay.
next look at grounds.
Check ground 101 (g101) - it is behind the left headlamp. Make sure it isn’t corroded, or broken.
then check ground 105 & 103 (g105, g103)
105 is bolted in the front of the engine/transmission.
103 is followed from that to the left lower front of engine.
there is also a ground under the front drivers seat that I’ve seen corrode bad. It is a main ground for the BCM.
If if they all look good, take a look at the Body control module (BCM)
they are a big issue on these cars, give the BCM a good smack and they try restarting the car, usually it will fire up, if the BCM is the problem.
Hope me this helps someone.
check the fuses,
under fuse block
IP IGN fuse (20amp)
Crank fuse (30amp)
