Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Turn Signal not resetting
Old Aug 4, 2012 | 4:20 PM
tap135's Avatar
Default Turn Signal not resetting
After making a left turn the turn signal wand does not reset. Anyone have a link or some info on removing the steering wheel and repairing?
thanks
Any chance of finding a service manual for the 07 cobalt?
Old Sep 16, 2012 | 10:29 AM
Welcome to the forum,
My daughter had this issue on her 09 cobalt, i was able to remove the indicator lever and open up the control box and re-bend the spring and lube the mechanism. It has worked fine since.
For manuals check Ebay, and there is always DIY Alldata.
I can provide a couple of pics I took while working on my daughters, don't know if they will help but I can post if you are still interested.
Old Sep 19, 2012 | 6:16 PM
BrandonHHR's Avatar
Turn Signal Canceling Failure Fix: Lots of Pics - Chevy HHR Network
Here is a link to the fix on an HHR. The cobalt is the same setup. It is a common problem. I had mine fixed while still under warranty. Hope this helps!
koobiidoobii
Aug 22, 2022 5:21 PM
fishingpro77
HHR
Aug 4, 2016 12:44 AM
lspencer001
Nov 29, 2013 7:29 PM
RomanGuzi
Oct 2, 2011 11:40 AM
derrik38
Jun 4, 2007 10:02 PM
