Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
Trouble with gas tank on 1989 corvete
Old Dec 27, 2020 | 9:09 PM
John Shoemake's Avatar
Default Trouble with gas tank on 1989 corvete
My son came home one day and he told me something was wrong with the gas tank. I looked at it and it was leaning to the left and the tank had moved . Where you put gas in had dropped down. Will take any help on this thanks.
Old Dec 28, 2020 | 10:45 AM
when you open the fuel cap after driving; do you hear a vacuum release?
Old Dec 28, 2020 | 10:53 AM
Yes when we remove the gas cap we hear vacuum release
Old Dec 28, 2020 | 10:57 AM
the tank must vent pressure and vacuum. when the pump runs and fuel is pumped out...air must flow in or the tank collapses. this is your movement. What ever is used to vent the tank is blocked. Not sure what they used in 89. maybe the cap itself. Modern vehicles vent thru the evap cannister and cannister vent valve.
Old Dec 28, 2020 | 11:28 AM
What is the easiest way to fix this problem with the tank.
Old Dec 28, 2020 | 11:34 AM
try a gas cap. get the correct one; new from a jobber or dealer. if that doesn't fix it...take it to a shop.
Old Dec 28, 2020 | 11:53 AM
Ok thanks for the information.
Old Feb 13, 2021 | 9:46 PM
chevyboy@22's Avatar
If you hear a hissing noise while pumping gas into your Chevrolet Corvette, you may need to change the Corvettes tank. It is possible that air or gasoline is seeping out of the container of the coupe
ofblong
Jul 23, 2016 10:21 PM
menacer1974
Apr 10, 2015 9:53 AM
tylerzambori
Oct 9, 2014 9:59 AM
Rowdyc
Dec 1, 2013 8:36 PM
konatown69
Oct 31, 2011 7:06 PM
