Chevrolet Cruze
Also Check out CruzeChat.com
2011 Cruze 1.8 transmission issue
Old Jul 12, 2021 | 7:41 AM
mj24's Avatar
Angry 2011 Cruze 1.8 transmission issue
Sorry for the long post
Got a 2011 Chevy cruze 1.8 had a output speed sensor code. Transmission would go into limp once light came on. Changed sensor and was great for about 65 miles then light came back on this time only speedometer would drop to 0 then back at correct speed trans shifting fine. Was told to change TCM so I did. Now the car wont move at all. Had TCM programmed and they did update on PCM as well. Only way to make car move is to hook up scanner and start it in 3rd gear then it will shift through all gears on lift. Had a P0872 come up so dealer sent me a new TCM with solenoids. Put it in and still no movement. Had this TCM programmed also. Now there are no codes but car does nothing. If I manually go from 1st to 2nd the car backs up.
mustafaelsayed
Cruze
15
Oct 29, 2023 4:59 AM
Bigfish3
Cruze
13
Feb 19, 2022 12:15 AM
jake knox
Cruze
Jul 12, 2020 6:46 PM
sathishraju
Cruze
Nov 2, 2012 9:55 AM
irene91744
Cruze
May 14, 2012 1:37 AM
