2014 cruz bellowing white smoke
I have a 14 cruz 1.8 had a failed oil cooler I believe as coolant was leaking into the oil. Changed the oil cooler now oil is clean and coolant bottle is staying full no leaks. But my issues is soon as I start the car it just bellows white smoke out the tailpipe to much that I can't even drive it to try and clear it out. I'm guessing the cylinders, exhaust and cat had a mmbunch of liquid in them from failed oil cooler. What can I do to get the smoking to go away or even a little better to be able to drive it and burn off what's in the exhaust? I don't think headgasket is bad as coolant was disappearing overnight before oil cooler replacement and now it's not. Any ideas what I should do? Also compression is between 215 and 240 on all cylinders
Nathan A
Feb 15, 2021 2:15 PM
