Chevrolet Cruze
Also Check out CruzeChat.com
2014 cruz bellowing white smoke
Old Dec 6, 2023 | 9:57 AM
malibu6767's Avatar
Default 2014 cruz bellowing white smoke
I have a 14 cruz 1.8 had a failed oil cooler I believe as coolant was leaking into the oil. Changed the oil cooler now oil is clean and coolant bottle is staying full no leaks. But my issues is soon as I start the car it just bellows white smoke out the tailpipe to much that I can't even drive it to try and clear it out. I'm guessing the cylinders, exhaust and cat had a mmbunch of liquid in them from failed oil cooler. What can I do to get the smoking to go away or even a little better to be able to drive it and burn off what's in the exhaust? I don't think headgasket is bad as coolant was disappearing overnight before oil cooler replacement and now it's not. Any ideas what I should do? Also compression is between 215 and 240 on all cylinders
Old Dec 6, 2023 | 4:39 PM
how would coolant get into the cylinders from a failed cooler? Even if it did, it would burn off pretty quickly.
Billowing white smoke is a textbook sign of blown head gasket.
Old Dec 6, 2023 | 4:41 PM
fparkin's Avatar
did you change the oil or make sure its not milky ,only thing to is let run and let it clear out
Nathan A
Feb 15, 2021 2:15 PM
dlaroche
Oct 29, 2014 7:17 PM
Janelle1985
Aug 28, 2013 12:26 AM
cb1
12
Dec 18, 2009 12:43 PM
