Chevrolet Cruze
Also Check out CruzeChat.com
View Poll Results: How do i retrain my 2015 Cruze LTZ
How splice pigtail wires correctly
0%
How to retrain my 2015 Cruze LTZ
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2015 Cruze LTZ
Old Mar 21, 2023 | 8:32 AM
JENN11554's Avatar
Default 2015 Cruze LTZ
my 2015 Cruze LTZ was vandalized. Wires were cut among other things.
The O2 sensor wire was cut in the wiring harness and the actual wire that comes on the sensor. I got a new O2 sensor and spliced the wires in the harness with the new pig tail.
the throttle body harness was cut. I replaced that. Also the hose from the coolant reservoir was cut. I replaced the hose.
The screen was also stabbed. The radio will still play but will the broken screen interfere with the car starting?
My car won’t start. Is there a learning process to go through before i can start the car?
i do some auto mechanics but am at a total loss and i really need this car running. Any help will be appreciated.
Old Mar 21, 2023 | 5:27 PM
oilcanhenry's Avatar
The O2 sensor wire was cut in the wiring harness and the actual white that comes on the sensor. I got a new O2 sensor and spliced the wires in the harness with the new pig tail.
I dont think I can help you, but you have my condolences for the damage done to your Cruze. I can advise you to run some OBD II diagnostics, which might help.
Old Mar 22, 2023 | 7:51 AM
bearbait's Avatar
I'm thinking you had some amateurs trying to steal your car. They couldn't get it started and got mad and stabbed your radio. I would check all the wires under the dashboard very carefully.
Old Mar 22, 2023 | 8:34 AM
Make sure that all the wires that you spliced back together are hooked up correctly.
Elaine Whisman
Cruze
Jun 19, 2018 5:29 PM
skiwings1
Cruze
Aug 6, 2017 3:19 AM
JLee15
Cruze
Jul 27, 2017 9:35 AM
szormia32
Cruze
Feb 27, 2015 4:50 PM
