View Poll Results: How do i retrain my 2015 Cruze LTZ
How splice pigtail wires correctly
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2015 Cruze LTZ
my 2015 Cruze LTZ was vandalized. Wires were cut among other things.
The O2 sensor wire was cut in the wiring harness and the actual wire that comes on the sensor. I got a new O2 sensor and spliced the wires in the harness with the new pig tail.
the throttle body harness was cut. I replaced that. Also the hose from the coolant reservoir was cut. I replaced the hose.
The screen was also stabbed. The radio will still play but will the broken screen interfere with the car starting?
My car won’t start. Is there a learning process to go through before i can start the car?
i do some auto mechanics but am at a total loss and i really need this car running. Any help will be appreciated.
The O2 sensor wire was cut in the wiring harness and the actual white that comes on the sensor. I got a new O2 sensor and spliced the wires in the harness with the new pig tail.
I'm thinking you had some amateurs trying to steal your car. They couldn't get it started and got mad and stabbed your radio. I would check all the wires under the dashboard very carefully.
