Chevrolet Cruze
Also Check out CruzeChat.com
2016 cruze wont turn off
Old Nov 7, 2019 | 10:11 PM
Kfrancis's Avatar
Default 2016 cruze wont turn off
I have a 2016 cruze 1.8L that will not turn off. We can turn the ignition into the off position and remove the key but the car will still run. Any idea what could be causing this?
Old Nov 8, 2019 | 5:22 AM
oilcanhenry's Avatar
Not off hand. Could be a bad ignition switch. The Cruze is built in Mexico, so Q-C is not as good as Fairfax, Kansas, where my 2015 Chevy Malibu was built by union workers who are strike at this time..
Old Mar 7, 2020 | 5:56 AM
Melinda Russell's Avatar
What did you find out was wrong with your car when it did this? Same thing happened to my daughter's Cruze last night? She had to change the battery in her fob. Plus her car says no fob detected. but I'm hoping it just needs to be reprogrammed.
Old Mar 7, 2020 | 6:46 AM
I had that happen many years ago in a Trailblazer. Turned out a relay in the fuse box overheated and shorted out the fuse box.
Old Mar 7, 2020 | 6:52 AM
Kfrancis's Avatar
We never figured out what it was. We ended up using the spare key to see if the key was the problem and it never happened again. We have since used both keys and still havent had the problem. Sorry I couldnt be of more help.
Kplott31
Cruze
Mar 26, 2019 11:28 AM
JP!
Cruze
Sep 12, 2016 8:32 PM
Rick_Witt68
Cruze
Jun 22, 2016 11:20 PM
jaha40
Cruze
Mar 28, 2014 12:21 PM
crashhat69
Cruze
14
Dec 4, 2012 7:12 PM
