Chevrolet Cruze
Also Check out CruzeChat.com
Clutch woes
Old Jun 5, 2022 | 1:54 PM
Caribchakita's Avatar
Default Clutch woes
Greetings all,
We have a Chevy Cruze, diesel, manual. In a nutshell: The slave cylinder disintegrates from the inside, contaminating the fluid with debris. The debris clogs the tube and prevents the hydraulic clutch from operating. Additionally in Europe they acknowledge that this contaminates the brake master cylinder and ABS module, so they replace all of those components in their recall.
The European recall for the car that uses the same transmission and components is here:
https://www.vauxhall.co.uk/astra-k-recall.html
In America, there is only a Technician Service Bulletin on what parts to replace, but the cost is only covered under warranty. That TSB is here:
(attached)
The parts we need are the updated slave cylinder, associated pipe work, and the clutch disc and pressure plate. I just checked the aftermarket by the way and they are backordered as well.
We are told the parts are months delayed. I cannot sell it in good faith and a dealer won't take it because of after market modications.
Thoughts or recs are appreciated
Annie and Seth
tank1949
1988 - 1998 (GMT400)
Jul 28, 2021 6:40 AM
ZChevyAK
Nov 23, 2013 8:36 PM
cxhxexvxy
Aug 18, 2009 2:16 AM
davidb
Dec 21, 2008 9:07 AM
