Chevrolet Cruze
Also Check out CruzeChat.com
Rough Idle & coolant fan stays on! 2011 Chevy Cruze 1.4 Turbo
Old Sep 16, 2019 | 9:58 AM
Viçtoria B's Avatar
Default Rough Idle & coolant fan stays on! 2011 Chevy Cruze 1.4 Turbo
Where do I start.. the other day I noticed my car was idling a little rough. And all the sudden the check engine light comes on. so I take it to have the codes read and it gave me 5 different Codes.. First they said was the MAP sensor. The girl at AutoZone told me to just clean it this happens all the time so I did. After I started my car again it's now idling even rougher. And now the coolant fan does not shut off after I turn the car off for about 5 minutes it stays on. What is going on?? I've had no problems with this car! I will say I've used the air conditioner a lot because it's over 102° where I live in Northern California. If somebody could please give me some pointers and tell me what I should do.. My engine is shaking from the idling too high and why is the coolant fan staying on now? I need help as soon as possible I need my car to find a job!! Thank you in advance, Victoria.
Old Feb 25, 2020 | 12:11 PM
Christine McWilliams's Avatar
Default Call gm motors!
The same thing is happening with my 2014 Chevy Cruze LTZ. Make sure you call gm and make a complaint about this! A month and a half ago, i just had my water pump, water outlet and thermostat changed in my coolant. I am currently at a Chevy dealership getting my reservoir replaced bc that is leaking now. It’s def not an cheap fix, and Chevy will only pay for the pump. This is a common thing to happen in Chevys, and it def needs looked into. It seems to happen a lot more right after the warranty is up, almost like a set up. Gm had told me the more people who call about this, the better the chance they will do a recall.
Old Aug 9, 2021 | 10:24 AM
money pit owner's Avatar
I work in over 110 and the fan is designed to stay on when the engine is in that hot environment to help cool the engine. The idle I would replace the spark plugs.
bwelsh822
Cruze
78
Jan 23, 2021 8:24 AM
Viçtoria B
Cruze
Feb 25, 2020 12:09 PM
Nam.alexandria
Cruze
May 16, 2018 10:13 PM
edsproblems
Cruze
Feb 1, 2018 4:23 PM
awowra
Cruze
Feb 18, 2014 2:22 AM
