Chevrolet Cruze
Also Check out CruzeChat.com
Temp sensor
Old Apr 19, 2019 | 4:08 PM
spanditt's Avatar
Default Temp sensor
I bought my 2013 Cruze in 2016 and I’ve had to replace the temperature sensor every year since I bought it. This cannot be normal, can it? It’s been in the shop twice within a week for the same issue. The first time the said it was the water pump and replaced it, but i never had an issue with it overheating. It would say “a/c off due to high engine temp” and the fan would run incredibly loudly.
Old Apr 20, 2019 | 7:21 AM
Who is doing the work and are they using quality parts or the cheap parts from China?
Old Apr 20, 2019 | 9:10 AM
spanditt's Avatar
. They put one in from GM and it’s right back in the shop for the same issue.
Old Apr 20, 2019 | 1:51 PM
what is the code that is setting.
without knowing the code...my guess is...if the engine coolant temp sensor is telling the pcm the car is overheating...the pcm turns the fan on to prevent an overheating condition. if the coolant temp sensor is showing a false reading....to hot in your case...the fault is from either a bad sensor, shorted wiring or bad pcm. testing is needed to determine which one is the fault. the fault must be active at the time of diagnosis...impossible to find a fault that is not active.
Old Apr 20, 2019 | 2:09 PM
Irish_alley's Avatar
I'm here for the party
tech, i know if you unhook the coolant sensor wire it will turn the fans on. will doing this also put the engine into the limp mode?
Old Apr 20, 2019 | 2:26 PM
i' don't think so...but I would never say never. It won't on most vehicles!!! it will set a coolant temp sensor circuit high code...the pcm will go into a heat strategy mode.
Old Apr 20, 2019 | 2:29 PM
btw to those that dont know this is a good way to test your electric fan/s
Old Apr 20, 2019 | 2:32 PM
..yes
Old Apr 20, 2019 | 3:11 PM
spanditt's Avatar
I don’t know what the code is, the garage just says the sensor needs replaced again, but one would think that there would be a reason that it keeps going bad on a yearly basis. I know when it went bad a couple days ago I had problems getting it started and they said it was because it was telling the computer that the car was too hot.
Old Apr 20, 2019 | 7:26 PM
find out the code and post it. can't help you without it.
