Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
305 to 383 swap transmission help
Old August 11th, 2011, 11:54 AM
zannesu2's Avatar
Default 305 to 383 swap transmission help
i have a 82 firebird with a 305 small block 4 speed manual.
now ive heard that when i swap engines that the transmission will bolt right up but that it wont be able to handle the proformance i want to get out of my car so i was going to upgrade to a transmission from a 350 just grab something from pick and pull untill i can get money for new stuff. what problems will i encounter swaping them what will fit into my car should i bother with it? suggestions? i basicly want a 383 with decent top speed and good low end torque without droping 3grand into my car atleast not yet
Old August 12th, 2011, 2:05 AM
Banned
T.Neff's Avatar
Look for a T56 over the T5 you have now.Not the best solution,but better than where you are now.
Old August 12th, 2011, 11:17 AM
zannesu2's Avatar
kay i know that the t5 5 speed manual is a peace of crap but i did say 4 speed so is the 4 speed garbage? i would prolly be better off with the 6 speed just because those extra gears will give me more acceleration. and my 2nd question is since that the 6 speed is bigger would it still fit under my car with no troubles? and what about shift kits is there no point to that?
87caprice718
July 29th, 2015 5:16 PM
gradyj
September 27th, 2012 10:47 PM
jpisyourman
Silverado & Fullsize Pick-ups
March 7th, 2011 1:25 PM
DixieD
May 7th, 2008 1:43 AM
Quick Reply: 305 to 383 swap transmission help
