350 Vortec Crate Engine
Old September 28th, 2019 | 8:03 PM
carnutbill's Avatar
New User
Awaiting E-mail Confirmation
Default 350 Vortec Crate Engine
I'm installing a 350 Vortec Crate Engine with a carburetor in my hot rod, what distributor can I use that does not need a computer? A HEI with a coil built in the cap would be hard to get in because of it's size & firewall. If I use a points distributor with vacuum advance & pertronix conversion kit do I need a different distributor gear because the engine has a roller cam?
Old October 3rd, 2019 | 10:03 PM
Ricardowelch's Avatar
Originally Posted by carnutbill
I'm installing a 350 Vortec Crate Engine with a carburetor in my hot rod, what distributor can I use that does not need a computer? Visit Rocketcarparts to find what is the best double din car stereo if you concern. A HEI with a coil built in the cap would be hard to get in because of it's size & firewall. If I use a points distributor with vacuum advance & pertronix conversion kit do I need a different distributor gear because the engine has a roller cam?
You can access hotrod.com with the title Chevy Hydraulic-Roller Cam: Get the Right Distributor Gear, so you can find down the answer. Hope it help.
StudeTom
June 7th, 2016 8:34 PM
dartonvpr
April 25th, 2015 10:30 PM
BretNasty
May 5th, 2010 8:46 PM
Quick Reply: 350 Vortec Crate Engine
