Chevrolet Equinox
Platform: Theta
2005 ABS ligt comes on brakes pulsate
Old Feb 18, 2016 | 2:04 PM
Lehua00's Avatar
Default 2005 ABS ligt comes on brakes pulsate
I had my Chevy equinox since 2005. The last year it has given me problems with my ABS light and brake pulsates. Took it to the dealer once cost me 196.00 for the computer to tell them what was wrong. Left it there to have the problem fixed. Problem not fixed. $600.00 later and still have the same problem. You would think that the computer would know best. NOT. Change the front hubs and that lasted for 3 months. same problem again.
Read about the pigtail wires or wiring harness needs to be changed. I will try that next and see. Any other information out there would really help.
Old Feb 18, 2016 | 7:22 PM
what are the dtc that are setting.
is the abs pump activating at slow speeds
Old Feb 18, 2016 | 9:48 PM
cleveland63b's Avatar
ya that computer that tells you exactly what to fix must not be very smart....
Old Feb 19, 2016 | 11:11 AM
Lehua00's Avatar
Default cleveland63b
the computer that told the mechanics what to fix, and they still cant figure out the problem.
Old Feb 19, 2016 | 11:14 AM
Lehua00's Avatar
Default tech2
I am not sure what the diagnostic trouble code was, but will find out.
Old Feb 19, 2016 | 11:19 AM
Lehua00's Avatar
Default tech2
It pulsates when I step on it to slow down.
Old Feb 19, 2016 | 11:40 AM
Official GM Rep
Hello Lehua00,
This is certainly something we don’t like to hear, and apologize for any inconveniences caused to you. We would be more than happy to stand as an additional layer of assistance between yourself and your dealer. If interested, please send us a private message with your VIN, current mileage, full contact information and dealership.
Kindly,
Helen
Chevrolet Customer Care
Old Feb 19, 2016 | 10:27 PM
would be nice if it worked that way. the fault code only tells the mechanic what system the fault has set in. the mechanic must then determine if the fault is in the component, wiring or computer module.
sounds like your getting a false abs activation. this occurs when one or more of the individual wheel speed sensors signals drop out. this usually occurs at slow speeds, as that is when the signal is weakest. Its a inherent design flaw of passive wheel speed sensors and that is why industry is now using active wheel speed sensors.
the technician must determine which signal is falling out....it starts with scanning for an abs code if set. if none are set, the technician must record the event with a scan tool and plot out the recorded data in line graph format....then you can see which wheel the drop out is coming from.
Old Feb 19, 2016 | 10:28 PM
...my magic eight ball tells me what to fix.
Is the problem the wiring harness....ASK AGAIN LATER
Old Feb 20, 2016 | 8:06 AM
tomwalt's Avatar
Great input - this clearly explains what I have observed (but did not understand) on my intermittent 'ABS' fault indication.
