2007 equinox heating problem
Hello, I got a 2007 equinox that is stumping me. At idle, heater blows cold, even when up to operating temp. Rev it up to 2500 rpm's, blows hot like normal. When driving, heats good, just coming to a stop, blows luke warm or cold.
Replaced the t-stat, water pump, flushed system, new head gasket 10,000 ago. Car has 130k. Any suggestions?????
<!-- / message -->
<!-- / message -->
<!-- controls -->
First check and make sure your coolant level is full when the engine is cold. If it is low on coolant, then the vehicle has a coolant leak and needs pressure tested to locate and then repair the leak, and the coolant refilled. Next is if your heater core is restricted. To find this out with a fully warmed up and running engine and your heater or defrost is on locate the heater hoses going into the firewall,touch both of them, they should be very warm to hot when touched and about the same temperature each. If one is hot, but the other is cooler, then the heater core is restricted, and it will need flushed out or replaced.
Amanda King (April 23rd, 2021)
Hi I have a 2007 chevy equinox it has been overheating. I have replaced the radiator the fans the water pump the thermostat and the temperature cooling sensor and it is still overheating any idea what it may be???
Official GM Rep
We understand you've been working to fix the overheating issue with your Chevy Equinox, but you're still experiencing this problem after multiple repairs. Sorry for any inconvenience this has caused. If you're interested in going to a dealership for additional assistance we're happy to set that up for you. Just private message us your VIN, full contact info, mileage, and preferred dealer and we'll gladly reach out to them.
Amber N.
Chevrolet Customer Care
Try flushing the coolant system and don't put in that orange coolant back in it! Use the universal green coolant, after it's flushed. Most likely, you have a clogged coolant system. That's what happened to my 07 equinox. Hope this helps!
I know this post is old.... But check the top hose to your coolant reservoir. I pulled mine off and stuck a coat hanger into the reservoir. Turns out it was clogged and not allowing the coolant to recirculate back into it. Fixed my no heat at idle! Something so simple. SMDH!
ruley73 (February 15th, 2021)
