Chevrolet Equinox
Platform: Theta
06 parking brake light
Old Nov 16, 2020 | 6:39 PM
ap4u06's Avatar
15 Year Member
Default 06 parking brake light
Spratic brake light comes on while driving. Parking brake is not on and nothing near it is hindering it. Parking brake is fully down.
Any suggestions?
thanks,
Old Nov 16, 2020 | 7:10 PM
ruley73's Avatar
Any suggestions?
thanks,
The brake fluid level in the reservoir is probably low. Before adding any fluid, check to see how much friction material is left on the front brake pads and the rear shoes if the drums are easy to remove. Assuming you don't have any brake fluid leaks, I'm betting the front brake pads and/or rear shoes don't have much friction material left. As your brake pads/shoes wear down it's normal for the fluid level in the reservoir to decrease. You're not actually losing fluid, more of it just stays elsewhere in the hydraulic system as brake linings wear down.
Old Nov 17, 2020 | 9:51 AM
ap4u06's Avatar
15 Year Member
Drove this morning and parking brake light stayed on all the time. (Changed cars and went to work) When I get home I will look and see about fluid before I go deeper. Thanks
Old Nov 17, 2020 | 11:02 AM
After you check the brake fluid level, check the switch for the parking brake. Is the ABS light on?
Old Nov 17, 2020 | 12:10 PM
ap4u06's Avatar
15 Year Member
I know for sure the abs light isn’t on. Will check the switch when I check the levels.
Old Nov 17, 2020 | 3:49 PM
ap4u06's Avatar
15 Year Member
Half of reservoir was empty. I filled to max line in brake cylinder. Hopefully this is all it is. I have felt worping of rotors hear pass week. Can feel it in the brake pedal as well.
Old Nov 17, 2020 | 4:58 PM
ruley73's Avatar
You should've only added the amount necessary to make the brake light go out. Now, you'll need to remove some of the fluid the next time the front pads are replaced. If you don't, the brake fluid reservoir will overflow when the caliper pistons are compressed prior to installing the new front pads. This is why I advised to check the brake pads first. As I said before, you haven't lost any brake fluid. More fluid just stays in the calipers as the pads wear and the caliper pistons extend further outward. The rear drum brakes don't hold more fluid because the wheel cylinders are forced to fully retract (by the springs) every time you let up on the brake pedal. Nothing forces the caliper pistons to fully retract until they are manually compressed during a pad replacement.
Warped rotors won't affect the brake fluid level.
Old Nov 20, 2020 | 12:16 PM
ap4u06's Avatar
15 Year Member
where is thee switch for the parking brake located??
Old Nov 20, 2020 | 2:31 PM
Don't know bout the Equinox, but they are usually by the parking brake pedal.
Old Nov 20, 2020 | 3:08 PM
fluid takes up the space of pad when it wears away. engineers are smart...the full level to "light on" level is calibrated...when the brakes and pads are new and the fluid is at the full mark..you are good...when the pads wear down to the point of turning on the warning lamp...the pads are near the end of life. you need to have the brakes inspected. you should never need to top up brake fluid.
jg33
Jan 3, 2021 3:17 PM
tyler11
Apr 27, 2015 8:58 PM
plush17
Jun 25, 2014 11:00 AM
whitedimond
Traverse
Dec 9, 2012 12:37 PM
pickeral
Sep 14, 2007 9:47 AM
