Chevrolet Equinox
Platform: Theta
07 Equinox--gear indicator showing "I" when gear shift in "D"
Old February 8th, 2017, 3:48 AM
ydissac85's Avatar
Default 07 Equinox--gear indicator showing "I" when gear shift in "D"
I'm planning to buy a 2007 Chevy Equinox with 96,000 miles on it from a trusted family friend who is a mechanic who has rebuilt cars for a living for decades. He has replaced the engine with one that has 81,000 miles on it. The car drives well and gears shift smoothly from what I can tell, but when I drove it, I noticed the gear indicator on the dash lights up "I" when the gear shift is in "D". He hadn't noticed the issue and says it's most likely electrical. Has anyone had this issue before? Is this most likely a simple electrical fix, or could it be a deeper transmission issue of some sort?
Old February 8th, 2017, 7:05 PM
ruley73's Avatar
The "I" is essentially the same as "D" except 5th gear is disabled. It is intended to be used for towing or hilly roads. I suspect that the shift cable needs to be adjusted. The shift cable is adjustable where the shift cable connects to the shift lever.
Old October 27th, 2020, 7:44 AM
Gwill's Avatar
Default Did you find a solution?
I have the exact same issue with my 07 Equinox. I was wondering if you were able to resolve it.
jim cutright
Chevelle & El Camino
November 3rd, 2017 10:39 AM
johndh
January 20th, 2015 4:50 PM
kellen.humphrey
June 23rd, 2014 7:34 AM
SSREIF
May 25th, 2014 1:21 PM
mattycakes
September 20th, 2013 10:16 PM
Quick Reply: 07 Equinox--gear indicator showing "I" when gear shift in "D"
