Chevrolet Equinox
Platform: Theta
08 Equinox Idle/Surge Issues
Old May 16, 2023 | 1:10 PM
TNMTNTOP's Avatar
Default 08 Equinox Idle/Surge Issues
Have a 08 Equinox that is idling rough. The rpms will be around 800 drop to anywhere from 200 to 400. Then surge.
I have been addressing computer errors as they arise. Replaced MAP sensor, MAF sensor, EGR valve and tube, vapor purge canister, O2 sensor, the negative battery terminal that was loose, on top of numerous shop repairs. Nothing has made it better or worse.
I did take a halo box to monitor the voltage on the battery. When not running the battery is at 12.6. When running it starts around 14.6. Then when the rpms drop the battery drops to just below 13 and gores back up to 14.6 when the rpms surge. So I can’t help but think it’s an electrical issue. Any suggestions???
Old May 16, 2023 | 9:40 PM
ruley73's Avatar
What codes are you getting? Which engine - 3.4L or 3.6L?
Old Jun 19, 2023 | 3:45 PM
TNMTNTOP's Avatar
Right now I don’t have any codes. The latest code was something about idling low. It’s the 3.4.
Old Jun 21, 2023 | 1:22 PM
TNMTNTOP's Avatar
So one of the causes could be the Evap which I haven’t fully replaced. Can anyone tell me how to properly remove these vacuum lines. I’m going to pull a part for replacements. And is the second picture the actual canister?
Old Jun 21, 2023 | 7:35 PM
-what are the fuel trim readings at idle and at 2500 rpm...this data can be used to diagnose a vacuum leak.
-have you ever cleaned the throttle body
Old Jun 21, 2023 | 7:38 PM
the pic is to close. the lines don't come apart;.they are molded. What is the globby mess in the top pic
Jeff Anderson
Feb 7, 2021 11:11 PM
msw3113
Nov 30, 2020 7:23 PM
mncmopars
Mar 25, 2015 10:20 AM
DBG53
Nov 3, 2012 12:08 PM
armyspader
Jan 25, 2010 2:16 AM
