Chevrolet Equinox
Platform: Theta
2007 Chevy Equinox heat
Old Oct 19, 2019 | 3:03 AM
Justin Nelson's Avatar
Default 2007 Chevy Equinox heat
Have a 2007 chevy equinox. The heat gets hot when the weather isnt very cold but once it gets real cold like 32 degrees outside or cder the heat blows cold air. Any suggestions from anyone?
Old Oct 19, 2019 | 7:39 AM
Doug D's Avatar
Check the coolant level. Low coolant level can result in low heat output.
It's also possible the heater core is partially or totally blocked. A flush using a product like Prestone SuperFlush may help. Best if you can swap the hoses connected to the heater core so you can reverse the flow and hopefully dislodge any blockage.
Old Oct 19, 2019 | 4:11 PM
ruley73's Avatar
Low coolant level, cooling system needs to be bled, or bad thermostat.
Old Oct 20, 2019 | 6:45 PM
Thanks fellas! Gonna try these tomorrow!!
cramer
Feb 1, 2022 6:31 PM
mutineer
Dec 19, 2017 9:06 PM
mswerb
Aug 24, 2012 11:32 PM
diamondtrail05
Mar 24, 2010 5:22 PM
tloliver
Mar 8, 2010 6:38 PM
