2007 equinox speedo and tranny problems
Hi all I am new here just bought a 2007 equinox LT AWD and immediately started experiencing problems. Speedometer would quit working transmission would shift hard especially between 3 and 4 and down shift hard rpms would jump up high between shifts. The stabil track light came on and put the vehicle in limp mode. The mil cam e on I retrieved 2 codes $7E8 transmission control circuit failure to communicate and $7EA transmission control system, according to my coder reader. I replaced the output transmission speed sensor (oss) cleared the codes speedometer works intermittent like before trans shifts great when speedo works but when it stops it goes to nuts. I have not gotten anymore codes out of it I did have the key issue a couple of times I couldn't start then had the key stuck in it a few times. I checked ground connections connectors on tcm, ecm, bcm and replaced the tcm with a used known good one vehicle acts just like before. Occasionally when I start the car the speedometer will show a high speed like 80 then start going backwards, it did this before and after all the work. Anyone have this issue before? I am thinking its in the bcm but not sure, also any one know exactly what sensor the speedometer uses to calculate vehicle speed? Any help would be appreciated.
ChevydotCom
October 13th, 2012 9:53 PM
89silverado283
February 16th, 2010 8:50 AM
