Chevrolet Equinox
Platform: Theta
Axle issues
Old Jun 18, 2021 | 12:24 AM
Shaggy037's Avatar
Default Axle issues
Is it just me or does anyone else replaceing passenger side axle every 6 months? This is ridiculous i am a die hard chevy guy chevy aint built like they used to be but anyone have any tips or maybe reasoning behing my axle snapping every 6 months
Old Jun 18, 2021 | 11:13 AM
ruley73's Avatar
What year, engine, and AWD or FWD? I'm guessing it's a 2005 or 2006 AWD. If it is, make sure you're installing the right part. Many of the aftermarket catalogs list the wrong axle for that application. GM changed it from a two piece design with an intermediate shaft & outer CV axle to a single, longer CV axle. The revised, longer shaft is GM p/n 22718646. It's discontinued at dealerships, but still available as an AC Delco aftermarket part under the same part number.
Old Jun 18, 2021 | 3:57 PM
Shaggy037's Avatar
its a 2017 fwd 2.4L
Old Jun 18, 2021 | 11:08 PM
ruley73's Avatar
its a 2017 fwd 2.4L
I should've known it was a newer model based on what I saw in the picture. The only suggestion I have is to make sure all the engine & trans mounts are still good. The top right engine mount would make the most difference on that side. If that mount is sagging, it might negatively change the geometry in a way that might put more stress on the right CV axle.
Old Jul 10, 2021 | 1:58 PM
Good4JG's Avatar
I had something similar happen with my first car - a 1986 Cavalier. I slid off the road and over a curb two weeks after I bought it. I replaced the bent lower control arm, bent wheel, and punctured tire and took it for a wheel alignment. I thought all was well until after I had replaced three axles and got underneath the car to look more closely. That's when I got under the car again for a closer look and found the suspension subframe (that bolts to the bottom of the car) had been pushed out of alignment. The symptom I had (but ignored) was a momentary vibration when the suspension was compressed or extended while driving (this is also a symptom of a bad engine mount, which another poster already mentioned). Regards.
BowtieTillIDie1994
1988 - 1998 (GMT400)
14
Nov 15, 2024 5:38 PM
willoamleon
Jul 8, 2019 12:38 AM
Yogi
Mar 7, 2014 4:02 AM
Mark3100
Oct 23, 2012 9:09 PM
jffgin
Sep 23, 2007 7:11 AM
