Battery Life
Battery Life
Checking the consumables on my Equinox to determine the cost and instructions on how to replace them I've learned that it takes an AGM battery that is about triple the cost of the old lead acid batteries. Any ideas on how long these AGMs last?
Average battery life for automotive use - regardless of what materials they’re made from - is about 5 years.
Like most other components, it’s going to depend on your driving habits. If you mostly make short trips, the battery may not be able to completely recharge - conversely, longer drive times will allow for it.
Xeroid (December 16th, 2020)
Thanks for the response. I guess I was hoping to get a cost per mile that's comparable to the old led/acid flooded batts. I'm used to seeing failure any time after 3 yrs.
The start stop feature will probably cause earlier Batt failure in that case. Thanks again!
Xeroid (December 17th, 2020)
The 2 battery setups are common, but I think they're a terrible way of implementing engine stop/start (ESS). The way most 2 battery systems are configured, if one battery starts to go bad, it becomes a parasitic drain to the other one. They're wired in parallel with each other most of the time, but are electrically separated during an ESS event. Our 2018 Chrysler Pacifica has ESS with a 2 battery setup, and premature battery failures are extremely common. Some owners have had their batteries replaced two or three times under warranty. I think in the case of the Pacifica though, the main battery isn't powerful enough from the start.
As far as the original inquiry goes, I highly recommend only using an AGM battery if that's what the vehicle originally came with. AGM batteries tend to last longer than conventional flooded-lead acid batteries in most situations. When compared to a conventional battery of the same size, you'll find that AGM batteries have significantly more power capacity. They also have better drain/charge characteristics which makes them better suited for newer vehicles that apply deeper drain/charge cycles to it than older vehicles did.
I won't use a lead acid battery unless it's an emergency. Another story I got from the dealer (salesman) is that the alternator is used to start the engine in start/stop mode. Anyone know if that's true?
https://gm-techlink.com/?p=8493
tech2 (December 18th, 2020)
the second battery situation can cause problems. Knowing what build you have and finding the 2nd battery is hard with aftermarket service information. If they are not isolated during testing a bad battery can test good.
ruley73 (December 18th, 2020)
