Can't get the front drive shaft off 2007 awd equinox
Hello.
I broke a u-joint on my 2007 Equinox drive shaft and damaged it. I purchased a new after market one but I cannot, for the life of me get the front of the front drive shaft out of the transfer case or ptu or what ever it is called. I pulled the universal apart trying to get it out but the front part of the universal housing is stuck there.
I tried hammers, pry bars, and an air chisel. Is there a special tool or way of doing it? I need help.
I see that on a lot of the forums people are just taking the prop shaft off and not replacing it. I am guessing they are having trouble too. I bought an all wheel drive vehicle and I would like to keep it that way if I can.
Help....plz!
Have you figured out how?
cannot, for the life of me get the front of the front drive shaft out of the transfer case either.... I read the pdf someone suggested and did that but it will not release... crowbar/pry bar hammer chisel
best method is with a hammer and chisel. i use an air hammer with a chisel bit but you better have a quality air hammer...if not use a regular hammer and big sharp chisel. remove the center support bearing so the shaft has room to move.
Dlmay81
January 13th, 2013 11:40 AM
