Chevrolet Equinox
Platform: Theta
change battery no start no crank
Old Jun 15, 2014 | 4:08 PM
oneswtrx's Avatar
Default change battery no start no crank
I have a 2008 equinox sport disconnect battery for 2 hrs no nothing no crank no start all different lights on dash stability track air bag engine service soon . Any ideas
Old Jun 18, 2014 | 12:53 PM
Official GM Rep
Hey oneswtrx,
I’m really sorry to hear that you are having this problem with your Equinox and can see how it would be frustrating. It looks like you are turning to the forum for some feedback on how to solve the issue. Have you considered contacting the dealership about this concern? Please shoot me a message if you would like to discuss this further.
Enjoy your day,
Austin J.
Chevrolet Customer Care
Old Jun 19, 2014 | 8:40 AM
tomwalt's Avatar
Do you have these other problems - Is the key stuck in ignition, can't open/close windows, door locks not working, can't open rear tail gate, etc?
Old Jun 20, 2014 | 6:31 PM
oneswtrx's Avatar
Default now starts ground computer
i took it to the dealer and they told me that the ecu and fuse block was no good . but they also told me if I ground the ecu the car runs .and sure enough I did just that and its perfect now . got charged 500$ for them to tell me that . now how do I fix this ground issue
Old Jun 21, 2014 | 7:59 AM
tomwalt's Avatar
Ouch - I had a very similar experience but mine was the Body Control Module (BCM). I told Chevy it was bad and they charged me 4 hours labor ($450) to verify this because it was "throwing a lot of error codes" (ya right, the data bus was down due to the BCU).
Chevy should have included an estimate to fix it - I think they are the only ones that can replace the ECU, program it, and get the data bus working. Maybe you can find a 'Chevy Expert' in your area that can do it.
I think grounding the ECU puts it in 'limp home' mode - fuel economy will be poor and I don't know what the long term effect is. Might be OK around town for awhile.
How did you ground the ECU? - Just curious.
Old Jun 21, 2014 | 7:52 PM
ruley73's Avatar
Connect a wire between the metal chassis of the ECM and a good grounding point on the vehicle (such as the strut tower).
Old Jun 22, 2014 | 10:26 AM
tomwalt's Avatar
Thank-you - So it's just grounding the ECU frame. If so, disregard the 'limp home mode' I suggested on a previous post. If grounding the ECU frame works and fuel economy is acceptable (not too rich nor piston ping), I'd just make sure the ground was solidly attached and live with it while watching for additional issues.
Old Jun 22, 2014 | 8:42 PM
oneswtrx's Avatar
So far so good drives even better . Thanks everyone for ur input . I grounded to strut tower and no issues at all . I will eventually fix it at a later I need to find chevy expert in the nyc area . If anybody knows of one can u please let me know thanks
Old Aug 21, 2014 | 2:17 PM
akcalvery's Avatar
Default Me too
I have the symptoms listed after a dead battery. New to is 07. Key stuck in ignition, nothing lights up except the check engine light. No door locks either. Jumped to charge and still the same. How do I get it functioning again?
Any input is greatly appreciated.
Old Aug 21, 2014 | 3:21 PM
akcalvery welcome to the forum...
you might check for a mega fuse between the battery and the main fuse box..
also make sure the connections are solid and clean...
