Chevrolet Equinox
Platform: Theta
power window problems
Old Aug 5, 2012 | 12:07 AM
rcarnley's Avatar
Default power window problems
i have a 05 nox and the driver side would not work but all the other windows would so i started trouleshooting
checked fuses and relays all were fine
checked for broken wires in the door jam none broken
checked for power at the motor checked fine
so i figured the motor was burnt up
I started playin with it and found out that if i pull on the motor it starts workin for a couple hours and then i have to pull on the motor works fine again so i put a peice of cardboard behind it and it worked for a few days then started again any ideas would be helpful thanks in advance
Old Aug 5, 2012 | 12:30 AM
check for broken wires in the a-pillar from the door into the body
Old Aug 12, 2012 | 11:42 AM
rcarnley's Avatar
no broken wires
Old Aug 12, 2012 | 1:51 PM
kevinkpk's Avatar
Dosen't the motor ground to the frame?
Old Aug 13, 2012 | 5:53 PM
Originally Posted by rcarnley
no broken wires
Its so common that I'm surprized they're not. You pulled back the rubber loom to inspect , right?
justin69
Feb 28, 2015 2:54 PM
davbell22602
Mar 10, 2010 8:36 PM
fiteit
Jan 12, 2008 2:50 PM
lmiskowicz
Nov 21, 2007 9:02 AM
