remote anti theft relay question
has anyone found a remote type relay that can be put in the fuel pump or ign spot and then use your phone or a fob to deactivate the relay to turn off the fuel pump or the ing to help prevent your car from being stolen? yes i know it is not 100% as someone can back up with a tow truck and take it in a few seconds. but for the kia type gangs that want to take you car for a ride or to use in another crime it may be good to be able to disable it.
and ye i know i can install a switch and hide it but if i can find a relay that would be much easier. and my girl has a Hyundai that is in that kia gang list of easy cars to steal and she in 4 states away so it is not easy for me to help her, but if they have a relay that she could just plug in that would be good.
i found one that is a battery disconnect but then that resets the i/m readiness all the time and she has to have to working for plates. so maybe some here have an idea or may have them now. i see them on ebay and activated with the phone but they are gps and i do not know it that actually disables the fuel pump or ign.
thanks for any ideas
how old is the car? Cars with distributor's...you can get a switch that will disable the ignition coil...the kit is sold for all classic cars. New cars with dis ignition and no factory immobilizer. buy a security system from any remote start manufacturer...bulldog security is one such supplier but there are others. Bulldog Security Products (bulldogsecure.com)
thanks this is for new cars, for one my girl has a hyundia in the range of the kia boys rampage and i have a 2016 chrysler with push button start and these seem to have full time fob to car transmitting. i know i can install a switch but i was hoping to find a relay that i could plug in and have a fob just to turn the fuel pump or the starter off when i leave the car and the same for my girl with the hyundia. they have no clue on how to instal a switch so they could put a relay in that is easy. i do not want to get one of those battery disconnects because they test for plates in az. where she is at and then the i-m readiness will fail if they use the battery disconnect
i did find a site that has them but they want a 100$ for them and i was hoping someone here may ve installed one and have a cheaper place to get them. it does not have to have a mile range just 50' would be good
i will check the bulldog site and see what they have thanks
